Frankthepressagent wrote:This car is showing a lot of corrosion. Probably due to salt contamination. I would be stunned if it was even salvagable.
Phantomrig wrote:Frankthepressagent wrote:This car is showing a lot of corrosion. Probably due to salt contamination. I would be stunned if it was even salvagable.
I have seen cars in far worse condition be restored to like new or better.
Tuckerfan1053 wrote:Phantomrig wrote:Frankthepressagent wrote:This car is showing a lot of corrosion. Probably due to salt contamination. I would be stunned if it was even salvagable.
Not to mention, with nearly mint models being worth $1 million, tossing the car away is simply not going to happen. If you figure that it takes them a couple of years to restore the car, Tuckers (as a whole) will probably go up a few thousand in value (haven't they gone up something like $250K in the past 5-10 years?), so even if the cost of the car, plus restoration put it over $1 million total, you'll be able to get your money back fairly quickly.
Return to Where To See A Tucker
