Larry Clark wrote:I will bite in your interest to continue a discussion, albeit I am not a Tucker old-timer of the era. About 1027, you make an interesting case for it to not be considered "lost" to this world.
Where are the pieces of 1027? The motor was removed from the car by the company well before the auction (not sure if the transmission was- likely it also was). Erza Schlipf began parting out 1027 as soon as he acquired it. The interior was back then put in to 1002. The fenders and bumpers are likely on 1050 (although there is also a contention that the front bumper is on 1049). Many Tucker cars have had more than one engine and/or transmission, a good many replaced by the factory (so it is not like a 1967 GTO where you might be concerned if you did not have the matching numbers 389 engine). The damage to the body from the roll over that Schlipf thought was too much to justify an attempt at restoration might be possible to be repaired with today's better technology and the knowledge that the car could potentially be worth big bucks when completed. Worth considering.
As an aside, I would still go look at what remains of 1027 just to see it.
