Tucker Technical Manual
Postby toolguybak » Wed Mar 28, 2007 9:10 pm
Hi All--I was going to order a copy of the Tucker Technical Manual and noticed they were out of stock. Will it be available soon?
Brian Kachadurian in Beverly Hills, near Detroit.
toolguybak
Postby Tuckerfan1053 » Thu Mar 29, 2007 10:56 am
Unfortunately, no. There's copyright issues preventing the republication of it. (One of the author's has since passed away, from what I understand and that's what's causing the problems.) Copies occassionally appear on eBay, so your best bet is to check there.
Postby toolguybak » Fri Mar 30, 2007 11:27 am
Thanks for the info. That's too bad. I've never seen the book, is it worth tracking down a copy? I was interested by the description on this site.
toolguybak
Postby Tuckerfan1053 » Sat Mar 31, 2007 2:11 am
Yes and no. It has tons of information in it that can't be found anywhere else, however, it's a bit lacking in details. A Tucker owner would find a lot of useful routine maintence information from it, but if you were going to rebuild the engine or transmission, it wouldn't be all that helpful. It is not nearly as detailed as a factory service manual produced by one of the car companies would be. If you can find one on eBay for roughly the same price the club charged for it, then I'd go ahead an get it, but if the seller wants something like $100 for it, I'd pass (unless it came with other groovy stuff).
Tech Manual
Postby Tom » Thu Oct 04, 2007 2:54 pm
I know Russ Brownells sons Russ Jr. And Larry Brownell i'll talk with them and see if they mind putting the manual back up.
Postby Tuckerfan1053 » Fri Oct 05, 2007 4:50 pm
Might I suggest lulu.com? It will enable the book to be published as a "print on demand" book and they won't have to fiddle with printing copies, etc. It'll also be available via amazon.com so they could potentially rack up more sales.
Postby TuckerCar » Sun Oct 14, 2007 8:24 am
