Tucker key? pics
Tucker key? pics
Postby bchunter » Sun Feb 12, 2006 3:23 pm
OK. I apologize as I am still learning to use a computer. Here is the link to the pictures of the key and lock I have that looks similar to a Tucker. You may have to login as a guest. Can anyone help ID this curious key & lock?
http://www.treasurenet.com/f/index.php/ ... 223.0.html
bchunter
Tucker key? Pics
Postby plancor 792 » Sun Feb 12, 2006 5:19 pm
Definitely not Tucker. See my post above.
Postby bchunter » Sun Feb 12, 2006 7:16 pm
Thanks Richard, It was a longshot. It remains a mystery.
bchunter
Lock?
Postby ehartman13 » Tue Feb 14, 2006 3:32 pm
If you look into the open area of that lock you will see that it is an early lug lock (replaced one of the lug nuts). My Dad had those and I think I have one just like it here somewhere. Hope this helps.
Eric
ehartman13
Postby bchunter » Tue Feb 14, 2006 8:37 pm
I thought of that. But it would only work if it was a 7/8" dia. stud! Did old cars have such large diameter studs? I tested on my truck, and it fits over the whole lug nut, but won't hold. Maybe with a special lug nut with a hole in the side to grip.
bchunter
