by Ganaraska » Thu Oct 27, 2005 2:58 pm
How about a link?
Not having seen the article yet I don't know what transmission you are talking about. I have a 1958 Standard Triumph sedan with automatic transmission, it is the Borg Warner T35 used by most English makes in those days.
The world's first production car with "hydraulic transmission", actually a fluid coupling and manual transmission, was the 1933 Lanchester "Fluid Flywheel" model.
This was the state of the art until the torque converter was invented. This was a fluid coupling with a 3d element added, a set of blades that diverted the flow of oil between the 2 existing sets of turbine blades.
It was the invention of the torque converter I believe, that got Harry Miller or Preston Tucker thinking that with the new torque converter you could eliminate the clutch, transmission, driveshaft and by using 2 torque converters (one on each end of the crankshaft) you could eliminate the entire rear axle and differential as well, and drive the wheels directly off the engine.
This would call for a rear mounted engine, of narrow flat 6 design, with a torque converter at each end of the crankshaft driving the wheels direct. With no gearing, it would have to be a very large displacement slow turning engine.
This I believe was the genesis of the Tucker Torpedo idea, a rear engine car with no clutch transmission driveshaft differential or rear axle, just 2 torque converters.
This is also the origin of the rumor that Tuckers wouldn't back up. There was not transmission, and no reverse gear. The torque converters had to be modified to make the stator blades reversible to make the wheels turn backwards and this was one of the technical problems that was never solved.
In the end the 589 engine and torque converter drive were abandoned for a transaxle design, the Y1 transaxle which was to be followed by a similar transaxle with automatic transmission and torque converter. The Cord transmission was used as a stopgap so they could get some cars running for test purposes.
