My Lego Tucker
My Lego Tucker
Postby P.J. » Mon Jun 07, 2010 4:44 am
I've been playing around in Lego's Digital Designer program recently and decided to make a Tucker. It's not perfect, mostly due to the limitations of the program but I thought I'd share it here since I can't upload it to the Lego site due to copyright restrictions.
Tucker 48 3.jpg (97.46 KiB) Viewed 711 times
Tucker 48 2.jpg (86.81 KiB) Viewed 715 times
Tucker 48 1.jpg (122.18 KiB) Viewed 717 times
P.J.
Re: My Lego Tucker
Postby P.J. » Mon Jun 07, 2010 4:47 am
2 more of the 48
Tucker 48 5.jpg (119.24 KiB) Viewed 705 times
Tucker 48 4.jpg (172.86 KiB) Viewed 726 times
P.J.
Re: My Lego Tucker
Postby P.J. » Mon Jun 07, 2010 4:51 am
I also decided to make a Carioca. Here's some pics of it, I'm currently working on a Talisman as well.
Carioca 3.jpg (96.4 KiB) Viewed 697 times
Carioca 2.jpg (110.38 KiB) Viewed 702 times
Carioca 1.jpg (131.1 KiB) Viewed 705 times
P.J.
Re: My Lego Tucker
Postby TuckerCar » Mon Jun 07, 2010 7:56 am
The Carioca looks great. Do they then let you order all the pieces you need to make them?
Re: My Lego Tucker
Postby P.J. » Mon Jun 07, 2010 9:26 am
They do. The problem is the cost. I priced them when I finished, the 48 is $280.57 and the Carioca is $152.83. I suppose it only makes sense
since the bricks are picked and packed by hand and you get to custom design your own box. Lego is nice enough to include a set of printed building instructions for free (If you ask for them when ordering) :lol:
P.J.
Re: My Lego Tucker
Postby P.J. » Mon Jun 07, 2010 3:05 pm
Just finished the Talisman. I had to take a few liberties with the nose and rear end design because I've only ever seen 2 pieces of concept art for the car, the side view and the top view. The cost for this one would be $239.94 according to the designer program.
Talisman 3.jpg (206.89 KiB) Viewed 648 times
Talisman 1.jpg (123.72 KiB) Viewed 652 times
Talisman 2 .jpg (137.07 KiB) Viewed 645 times
P.J.
Re: My Lego Tucker
Postby P.J. » Mon Jun 07, 2010 3:08 pm
3 more pics of the Talisman
Talisman 6.jpg (194.09 KiB) Viewed 644 times
Talisman 5.jpg (222.42 KiB) Viewed 643 times
Talisman 4.jpg (198.3 KiB) Viewed 641 times
P.J.
Re: My Lego Tucker
Postby Phantomrig » Tue Jun 08, 2010 2:11 pm
impressive work, its just too bad that they charge soo much for the parts to build your own creation.
Re: My Lego Tucker
Postby P.J. » Tue Jun 08, 2010 4:52 pm
I know. I tried making the Carioca into a convertible by removing the top and adding a boot to it and the price only dropped by $11.00 or so. If they weren't so expensive I'd order up one of each.
P.J.
Re: My Lego Tucker
Postby Tuckerfan1053 » Wed Jun 09, 2010 12:01 am
Have you seen this thread? Its got photos of a Lego Tucker someone built, and if I remember correctly, he didn't spend a huge amount of money on the project. Perhaps you can get some hints from the pictures or the links in the thread.
Re: My Lego Tucker
Postby P.J. » Wed Jun 09, 2010 4:19 am
I have seen that Lego Tucker, he did an awesome job on it but it's very small and the ones I designed are closer to, if not slightly larger than 1/18. Plus I read in the thread that he had to modify some of the bricks to get the correct look and fit and the digital designer program doesn't allow you to do that. I've thought of trying to make a scaled down version but I'm not sure I'll like the result as much. Who knows though, if I'm in the right mood I might just save up and order one of them, I really like the way the Cariocia came out and it is the cheapest of the 3.
Here's a few more pics of the 3 cars as convertibles. For the 48 I cut the model down to make it look like the Benchmark convertible. On the Talisman I made a large rollbar just after the door where the color goes 2 tone.
Talisman convertible 1.jpg (83.64 KiB) Viewed 554 times
Cariocia convertible.jpg (174.64 KiB) Viewed 545 times
Tucker convertible.jpg (94.52 KiB) Viewed 555 times
P.J.
Re: My Lego Tucker
Postby P.J. » Wed Jun 09, 2010 4:25 am
Here's one of the interior of the Talisman, It has a gauge cluster, front buckets with console and rear bench seat with arm rest. If you look closely you can see the top of the shifter and the blinker switch on the steering column as well as one of the interior opera lights on the B pillar.
Talisman convertible 2.jpg (202.97 KiB) Viewed 547 times
P.J.
