by NailheadRocketdriver » Wed Jun 25, 2008 7:25 pm
I'm actually still getting a Corvair, lost out on a couple cheapies, but theyre still out there. That's not a Tucker though, not anything close. Vairs came from Tucker's hometown and I suppose it was a way of getting that Tucker individuality back, but then again, it was more of GM's way of taking a stab at the Europeans and at Ford's Mustang at the same time. I'm not planning on getting an original Tucker and I would never attempt at getting one, even if I had the half million to do it. I think it's kind of pointless to spend a chunk of money on a classic car that i can't even drive. Real Tuckers are more like a fine samurai sword or a biblical artifact, you can't look at them in the same way that you look at any car. They are pieces of history and they probably shouldn't even leave the hands of the collectors that own them. What I'm planning on doing is cobbling a custom car out of spare parts and some hand fabricated components the best I can. I know that it's doable because I have seen some pretty interesting customs here in MN when I attended MSRA Back to the 50s at the state fairgrounds on the 20th of this month. Many of the rodders out there have probably make the same or even less cash than I do and what they came up with to drive into the events were amazing. The mini Corvair idea though..... that is kind of interesting. It's been done though. If you look around on this site for a link, you will probably see a Corvair convertible with a fiberglass front grafted on. It's more of a parade car than anything else, but it works. My dad wanted a mini Tucker, but I think that a Corvair four door (even post 1964) with Tucker styling cues would just look ridiculous. I'm rethinking using scrap metal to build the car just as Ricardo did outside under a tree in California, but making everything from scratch by using fiberglass is also tempting. it would take longer, but I would get to use the frame that I want with the powertrain that i choose without a problem. making all those compound curves would be alot easier too. All I would need is complete blueprints and molds,then I'd have a Tucker that was lighter and didnt rust! and like the original car...... parts can be substituted in.
