Instead of trying to answer different topics with reference to me I wish to give you the following information.
I would not believe a word that Reinert says. I have known him for years. He acquired 1043 from George Spiegel under terms less than honorable. It is said he also acquired sheet metal parts from the warehouse storage of the former owner of 1006, Richard Guzowski. I would suggest that someone contact Mr. Stan Gilland in Wellington, Ks. to determine what was at Ezra Schlip's and possibly Dewey Bloomquist places when he visited there. I know Stan had body 1055 and he also had a frame. I do not recall if this frame was from Body 1055 or if it was a different one. Between 1974 and 1975 a tree fell on that body as it sat outside Stan's shop and put a large dent in the roof. Mr. Gilland had Dave Cammack's Tucker's 1022 & 1026 at his business in Wellington to restore. For an unknown reason he stopped restoration on 1022 and eventually Dave picked it up and brought it to me. He also noted that 1026 was sitting in a field behind the business so shortly there after he also picked it up and deliverd it to me. Since that time I have had no contact with Stan. He did not reply to letters I sent him. I know that Reinert got a truck load of Tucker parts from Wayne McKinley who at one time owned Tucker 1036. Reinert told me this and ask if I would want to help him sort through the items so he could tell what he had. I did not. This so called convertible is a Reinert creation from beginning to the point where he was able to sell it off. While I look forward to seeing it should it make it to Amelia Island next spring I will never believe that it was started by Tucker Corporation as a secret project and they will never be able to prove it was.
The body of the Tucker is welded to the frame and must be cut off to remove it. In conversations I had with Nick Jenin he told me that all of the Tuckers he had were repainted and reupholstered. He also said most of the data plates were cut off and had been put back on with screws. Not all were returned to the original vehicle. When Nick got Tucker 1046 it was an original Tucker with the engiine in the rear. He used an Oldsmobile engine and mounted it in the front of the car for his daughter to drive. Later it was purchased by John Janecek who redid the vehicle using a 1964 Mercury engine, chassis and drive train. No idea as to what happened to that frame.
It is impossible for me to go back and dig out information that I may have had years ago. First, I am going on 80 years old and the old memory is not what it once was. Most of my Tucker material is in a climate controlled storage facility some distance from my residence. Due to medical problems I cannot go down there and spend hours searching through files. I have a spouse who has Alzheimer's, she also has heart disease and is a diabetic so most of my time is taken up caring for her. Then too I also have a few problems.
