Tuckeroo wrote:I don't believe Lawson was mentioned by name in The Indomitable Tin Goose, possibly because there was derision toward his design. Not that it was seen as unattractive, but to fanciful to be usable. I'll have to go back to the book and read the actual passage, but as I recall Pearson describes Preston Tucker turning green upon seeing the photos of what the unnamed designer produced, but that owing to time constraints they were used in press releases anyway.
Tuckeroo, you remember the story correctly. However, if you read my previous post you will realize there was no "turning green" as Charles Pearson claimed. Lawson worked on the design of the Tucker for 2.5 years, longer than any other designer. He also was publicly named the Chief Stylist of the Tucker Corporation in February of 1946. Would Preston Tucker have kept Lawson working on the design for 2.5 years and also name him the Chief Stylist in national publications if he was not satisfied with Lawson's work?
Another problem with the Pearson story is the fact that the "production" Tucker design is a direct descendant of the Lawson design. Tremulis did not start new, and he testified such in the SEC trial. Tremulis also testified that when he arrived in December of 1946 that a full-size rendering of the Lawson design was on the wall and that the engineering department was working on the blueprints to produce the Lawson design. Thus, Preston Tucker had every intention of producing the Lawson design and did not publish the Lawson design because he was forced to, as Pearson claimed.
Also, the fact that Preston Tucker planned to produce the Lawson design indicates that he did not consider the Lawson design impractical any more than the fluid drive or the 589 engine.
So, why did Pearson make up the "turning green" story? There are a many possibilities. The first is that Lawson had patented the Tucker Torpedo design in his name and then sued Preston Tucker for payment for his 2.5 years of work on that design. I bet that didn't make Lawson popular with the Tucker camp. (If you'll notice, the second Tucker patent is in Preston Tucker's name, not Tremulis and the Lippincott team. Preston obviously learned his lesson on that one.) Lawson was also the first witness in the SEC trial because as the original designer of the car he was, in essence, the first Tucker employee, the case being presented chronologically. Lawson testified against Tucker in that trial, another reason he wasn't popular with those who supported Preston Tucker - people like Charles Pearson.
Let's not forget that Preston's publishing of the realistic photos of Lawson's Torpedo model gave the public the false impression that he had a running prototype car. This instance has often been used by people as "proof" that Tucker was a fraud. Pearson's story that Preston Tucker only used those photos because he was forced would discount those claims. However, the facts show that Pearson's story is false.
