by Tuckeroo » Tue Sep 16, 2008 1:42 pm
Hi, The car was #1013, now in the Swigart Museum, and probably would've been owned by the Heinrich family in 1987 when the movie was filmed. I believe that Ohio would've been its home state at the time, too. It has a pearl-gray paint job with a hint of blue in it, probably lighter and more lustrious then the original pearl-gray from the factory. Of the 22 actual Tuckers used in the film, many suffered at least a bit of damage here-and-there either in shipping or during filming, but none quite as much as unlucky 13 from what I've heard. Many of the cars had pre-select mechanisms on the transmissions that weren't working very well, so in some cases the rear seat was removed and a technician would lie down on the rear floor of the car and operate the shift mechanism directly on top of the transmission! In the case of 13, the technicians failed to replace the rear seat in #1013, and it was left out in the weather. And while a lot of the chase scene was done with a replica - the difference can be spotted - I would not be surprised that the real Tucker in that scene was #1013 and that it suffered additional damage.
